unconfigure mpls
unconfigure mpls
Description
Resets MPLS configuration parameters to the default settings.
Syntax Description
Default
N/A.
Usage Guidelines
This command deletes all VLANs from MPLS and resets all MPLS configuration parameters to their default values. The parameters that are reset include the LSR ID, all LDP-specific settings, all RSVP-TE-specific settings, all RSVP-TE reserved bandwidth, and all EXP Qos Profile mappings. MPLS must be disabled to unconfigure MPLS.
MPLS must be disabled to globally unconfigure MPLS.
The following command resets MPLS configuration parameters to the default settings:
unconfigure mpls
This command was first available in ExtremeXOS 11.6.
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
